Stockage très long terme
MessagePosté le: Lun 28 Nov - 18:43 (2016)    Sujet du message: Stockage très long terme Répondre en citant
Supposons qu'on veuille stocker une moto entre 5 et 10 ans,
que faudrait-il faire Question Question
MessagePosté le: Lun 28 Nov - 18:43 (2016)    Sujet du message: Publicité
MessagePosté le: Lun 28 Nov - 19:03 (2016)    Sujet du message: Stockage très long terme Répondre en citant
1 réponse par un autre canal :
enlever la batterie ;
vidanger l'essence ;
laisser tous les fluides pour éviter la corrosion.
remplacer huile moteur + nouveau filtre avant remise en marche.
MessagePosté le: Mer 30 Nov - 08:01 (2016)    Sujet du message: Stockage très long terme Répondre en citant
j'ai fait un résumé de la même question posée sur ADVRider
STORAGE - Summary
Bodywork
Clean and lightly coat the outside with a protective oil, then wrap it up in an old pillow case - hang that up high.
Put the bike on its centerstand.
Extra credit for liberally coating the bike's plastics and rubber hoses with that aircraft grade vinyl preservative (NRS 303 Aerospace Protectant)
Stuff steel wool into the snorkel, maybe the airbox, and any exhaust opening, all to dissuade critters.
Electric
Completely remove the battery.
Engine
Fresh fluids, all.
Gasoline is the kicker. For only a year, or so, fill the tank with non-ethanol and add a can of quality fuel preservative.
Much beyond a year, however, I'd empty the tank and spray it with a fogging oil.
fog the cylinders with wd40
loosen the spark plugs a turn or two
Tyres
Inflate tires to absolute maximum stamped on their sidewalls.
Miscellaneous
Remove the canister
Put mouse traps or poison in the storage area.
RESTART
Finally, expect a fuel pump, hose, or similar failure upon the eventual unwrapping.
Tires may well be dry rotted.
Change plugs and ALL fluids + filters upon return, before riding.
http://advrider.com/index.php?threads/long-term-storage.1189713/
MessagePosté le: Sam 3 Déc - 19:20 (2016)    Sujet du message: Stockage très long terme Répondre en citant
CorrosionX : un produit adapté aussi à l'aviation :
http://www.corrosionx.com/corrosionx.html
MessagePosté le: Mer 7 Déc - 06:59 (2016)    Sujet du message: Stockage très long terme Répondre en citant
sac étanche + matériel dessiccateur + indicateur humidité Razz
https://www.vac-bag.co.uk/
MessagePosté le: Aujourd’hui à 02:20 (2018)    Sujet du message: Stockage très long terme
