RexXer Ecu Tuning
MessagePosté le: Lun 15 Fév - 14:07 (2016)    Sujet du message: RexXer Ecu Tuning Répondre en citant
à découvrir
http://www.rexxer.eu/e_maps.cfm
pas d'électronique sur la moto : on remplace la carte d'injection directement dans le module de contrôle
Up to now it was not possible to modify the fuelling map on your bike without using a tuning box module.
The RexXer now enables you to repgrogramme the stock ECU in 3 steps to swap the original map with a "tuning-map" that simply
uploads into the standard ECU via the diagnostic plug.
By using the Rexer you don't have to mount a module which remains on the bike.
1) Connect
2) readout the original Map
3) Upload the tuning map - finished!
MessagePosté le: Lun 15 Fév - 14:07 (2016)    Sujet du message: Publicité
