MAGURA HC3 - Radial Brake - Clutch
Poster un nouveau sujet   Répondre au sujet    Je me la pète en FLAT-BMW Index du Forum -> Accessoires -> Accessoires moto RACING
MessagePosté le: Ven 15 Jan - 10:05 (2016)    Sujet du message: MAGURA HC3 - Radial Brake - Clutch Répondre en citant
pour HP2 Megamoto Radial Brake (compatible ABS)
•High-grade alloy construction for maximum rigidity in a lightweight design
•Fully radial master cylinder design features patented braking technology that reduces internal friction to maximize feel at the lever
•Multi-primary port master cylinder ensures faster pressure balance when used with ABS brake systems; minimizes "ABS kickback"
•Fully compatible with ABS brake systems
•Three-way lever ratio
•Smoke-tint hydraulic fluid reservoir, banjo bolt and crush washers included
•Available for clutch and brake applications
•Brake master cylinders are fully ABE-approved
MessagePosté le: Ven 15 Jan - 10:05 (2016)    Sujet du message: Publicité
MessagePosté le: Ven 15 Jan - 10:12 (2016)    Sujet du message: MAGURA HC3 - Radial Brake - Clutch Répondre en citant
Embrayage
Magura HC3 Radial Clutch Master Cylinder - 15mm
•For use with DOT hydraulic fluid
MessagePosté le: Mer 30 Nov - 08:32 (2016)    Sujet du message: MAGURA HC3 - Radial Brake - Clutch Répondre en citant
BMW Performance Parts
http://www.magura.com/en/components/powersports/bmwperformanceparts/
MessagePosté le: Aujourd’hui à 02:17 (2018)    Sujet du message: MAGURA HC3 - Radial Brake - Clutch
Poster un nouveau sujet   Répondre au sujet    Je me la pète en FLAT-BMW Index du Forum -> Accessoires -> Accessoires moto RACING Toutes les heures sont au format GMT + 1 Heure
