Huile PONT - BOITE - CASTROL SAF-XO 75W-90
MessagePosté le: Jeu 20 Oct - 13:44 (2011)    Sujet du message: Huile PONT - BOITE - CASTROL SAF-XO 75W-90 Répondre en citant
recommandé par BMW
33117695240 FINAL-DRIVE GEAR OIL SAF-XO - OSP, 1000ML (LITRE)2.04 X  $47.83
Castrol SAF-XO synthetic gear oil is formulated exclusively for BMW gearboxes and rear-wheel drives that specifically call for this lubricant in the RSD. Bottle size: 1 liter/1000ml (1.05qt/33.8 fl oz). SAE 75W-90. Always reference the latest DVD repair manual for the correct filling quantities for gearbox and rear-wheel drive oil changes
http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9016057&…
MessagePosté le: Jeu 20 Oct - 13:44 (2011)    Sujet du message: Publicité
MessagePosté le: Jeu 20 Oct - 14:04 (2011)    Sujet du message: Huile PONT - BOITE - CASTROL SAF-XO 75W-90 Répondre en citant
Att.Castrol MTX FULL SYNTHETIC SAE 75W-140
API GL-5
www.castrol.com
recommandé par BMW
http://www.castrol.com/liveassets/bp_internet/castrol/castrol_switzerland/S…
MessagePosté le: Aujourd’hui à 01:35 (2018)    Sujet du message: Huile PONT - BOITE - CASTROL SAF-XO 75W-90
